Mark Gomez
is where the surf is
- Fullerton, CA
I dont have firsthand experience with Jetworks control valve, I always make my own, but unless they have some tricky little do dad in theres, its just a popoff device. Yes it natrually restricts flow due to design itself, it cant flow as easy as a single 3/8" line... But thats not the point.
The point is to add a bypass in front of it so not all the water is directed straight to your valve, instead diverting alot away, otherwise all your doing is stopping flow to the exhaust at Idle, then dumping a lot when the valve pops off. You have to lower the pop off of the valve to about 2-4 psi, and then play with the restrictor that you put into the bypass, I personally used a doubled sided brass barb fitting that had something like a 3 or 4 mm opening. Just make sure to test the thing before you really use it, making sure that the valve opens up around 3k rpms or something around there.
Yep thats pretty much what the flow control valve does. I have it adjusted to where it allows water through at 3500 Rpms but its to my stinger i think you might be talking about my head pipe line am i correct?
