Custom/Hybrid Poizen's Tiger craft Aqua-bot
PNW
(Enter Hull builder name here)___________________ needs to work on his customer service and quality control and he could have a unstoppable business
The above statement could be used over and over again for this small circle of builders!
I think your boat looks cool without the graphics, shows off the radical body lines!
Poizen
Mical
South Africa
fitted pump today
had to make a 5mm spacer
here you can see how off the pump alignment is and that's after I drilled those holes to 8mm ( dam why did I screw with the pump caused myself so much work now. *DOH what a joke)
now to find a happy place to cut the ride plate
needs a bath bad the white is horrible with dirt
also sorted out my trim. its still top pull I just shortened it down and fits and works beautifully
ProSouth
Seriously, Don't be a dick.
kawasakis suck
What the hells a pole spring? Lol it looks good.
and swapmeet, don't hate it cuz it's luxurious. Actually there's no real pink left except the pump.
Poizen
Mical
South Africa
Drilled a hole to fit my drain plug and guess what dah dah daaaNo flippen foam ( what did you say again Tony? ) unless you invented invisible foam
Also mounted the ebox
Roseand
The Weaponizer
Wisconsin
You were planning on two part foam right? You might be able to poor it down the drain plug holes maybe... Or is that unrealistic?
Sent from my XT907 using Tapatalk
Digging the all white and black theme. Ski is going to be really nice when done. Definitely looks better without the graphics, IMO.
SM
Poizen
Mical
South Africa
I think so my bad sorry my blood just risen from this
To call me a liar and state that this hull left the shop with foam
Wait I know the guys on the ship took a mould and made another and gave me the shoddy one and they kept the nice one
Thats the only explanation I can give over this whole situation
