@Quinc , You are sort of the Coffman Sizzler Guru. I got some temp strips and I was wondering where on the chamber I should put one, and what temp am I shooting for? Additionally, should I monitor manifold or headpipe temperature and if so what am I shooting for there?
Also what have you found when messing with water pressure and flow in regards to improving the pipe?
Starting out I was going to restrict all the outlets for engine and pipe to 1/4. The pipe has its own 3/8 feed at full pump pressure so its more pressure than most setups. I can restrict before the pipe to lower the flow and pressure if it has too much cooling or water injecting into the pipe.
And one last thing. Anyone know what temp I should look for on the head? Im sticking a temp strip on it to monitor temperatures. I know it climbs as you are taking the hood off I just dont know what temp to run at and how much it climbs.
Thanks a bunch for the help.
