Just as an example. 120hp stock w/ stock electronics, exhaust and dual 44mm carbs. Put a WDK exhaust, bump the compression from 120psi (stock) to 150psi, dual 48's, TL, v-force reeds...........on a stock stroke which is equivilent to a 10mm stroker 62t. I am willing to bet it would hook up with a 144mm pump, a TBM cone and the correct pitch c-75 impeller. Not sure what the exact HP numbers would be on that set up but I am willing to bet 150-160 is not out of the question. If you were to do a BB kit from either WDK or GroupK (87mm and re-nickisil plate the cylinders for faster piston speeds)...........that thing would flat out thump. Maybe do a 144mm mag set back on that set up. The big thing is getting that power to hook up.
