What about yours?Im so glad I was able to ride with you when you picked up this hull! Its great to see it transform the way it has. GREAT WORK DON!!! Always 100%
That was a good day!Im so glad I was able to ride with you when you picked up this hull! Its great to see it transform the way it has. GREAT WORK DON!!! Always 100%
What about yours?
Yep we used a pressure pot and spray grade adhesive at the cabinet shop I worked at, everything we did there was laminted onto particleboard , if it was a cabimet door it was laminated on all sides, the spray grade adhesive did dry much quicker and it was stout, better make sure the pice is where you want it before you stick it for sure. I just got done laminating all that metal to the plywood on my trailer build, I used a foam roller and a paint tray, I have to say it went on very nicely and quick, so there's another option for you.Been experimenting with the glue pot.Takes some time to figure out how much glue you want to come out of the nozzle.Too little glue doesn’t work and too much spatters out in snot balls.More about controlling how much air blows out of the gun than how much glue.Awful lot like painting a car.Testing with spraying cardboard helped me out.You can see from the tray and turf that there doesn’t look like much glue on either.And there may not be enough.Time and use will tell.That is part of the experiment,to see how much l need to use to make it work.lt is Dap headliner glue used in upholstery shops.Stronger than what’s in the dap red can.What l found out using the spray is there is less waste.Two light coats and it drys in less than 5 (per coat) minutes.That’s how uph shops do a car headliner.
Very close right now.Plan is to get it to the lake today or tomorrow.Got a funeral to go to this afternoon,so l have a busy day alreadyMe sitting here waiting for Don to finish this build…View attachment 430334
Looks real clean, nice work as always!
These are my favorite kind of builds. Very cool.Waiting on a starter to come.So decided it was time to make it look like a fx1
Thanks Boyer!Awesome build Don!
