The Madness continues as l am slowly getting things tied up.Closed off the driveshaft tube this weekend on the pump tunnel side by adding some thickened epoxy with glass strands to fill in around the tube and hull.Then wrapped some 12 oz carbon around the shaft tube connecting it to the inside pump tunnel.Also covered the front intake grate inserts with the same cloth.
On the outside of the 144 pump box in the front of the brass piece where you bolt the ride plate to,there is some “cutouts” that allow some extra room for the steering cable thru-hull nut.Well this space when you bolt an fx ride plate to it leaves about a space of .25” wide and 1.25” long gap.Sorry that was such a long explanation.
Filled that area in instead of just adding silicone later on.l had about half of the thickness filled in from a previous surplus of epoxy so wasn’t that much to finish.We’ll all that leads up to is now l can install the plastic steering thru hull without having to deal with sanding and trying to finish it later.
l also skim coated the end caps with faring to smooth out the 12 oz carbon previously done.This will allow the exhaust tube to also be installed,as well as the .50” water lines and trim tube possibly today.Pics later
*As a side note.Had a discussion with another rider this past weekend about using thickened epoxy with glass or carbon strands mixed in to use as a filler.l have had great success with the mixture over several builds,but l don’t think you should overly use the mixture.As in years past where a bodyman would use a 2 lbs of bondo to fill a dent.lt should be used as a “skim coat” or just in small amounts,then reinforced over with carbon or glass.Think of it as carbon rebar when using.Be interesting to see other opinions on this.Maybe should start a thread..
