Almost 2 months without an update.My lazy butt.
But today got back started on the project,thanks to
@brapperdoodle getting me inspired again.Thanks bro.
Most of what l was dreading was the sanding,a tyvec suit and basically getting airtight to keep the fiberglass off of me.Had a lot to do,about an hour and a half roughly.Soaked with sweat when l got thru,but no itching tonight.
Parts of the tray,the rrp foothold surrounds, and some reinforcement for the sides.The tray needed to be bonded on what was left of the front,about 2.5” and also at the rear bond rail.Some thickened epoxy with glass strands.The reinforcement mentioned earlier was for the side gunwales to make them more stout because of using rrp adj footholds.As you can see from the pics,l weighted the front with a gal paint can and then clamped the rear rail and also the sides.More thickened epoxy with glass strands added there too.
Tomorrow the plan is to epoxy the foothold surrounds with some added glass to seal them to the inside of the gunwales.Then l’ll be adding foam in the sides to form them out.Then more sanding….
