Freestyle RCW Brawler Build for 2016, ET1107 PICS ENGINE BUILT!!
Th3g3rm4n4t0r
Brawlin' n Flippin'
Good to hear you used a good a lube. I know it really sucks when someone comes into your thread and posts a bunch of stuff you would rather not read, but times have changed and people are "heart" felt about things they feel strongly about
Lube is lube, first run to break in ill use a non synthetic oil (canadian tire stuff probably) to cut the ring properly.
Th3g3rm4n4t0r
Brawlin' n Flippin'
Motor is in pics will be up later!! Working on my steering cable, throttle cable and pipe stuff now. Tapping a hole in my pump for a second pissa @alex_hockey that blocked off bung on the pump vane part itself i could tap here correct?
, also might cut and modify waterbox. Going to test popoff on carbs as well.
Dont know how much ill get done but ill try my best.
Th3g3rm4n4t0r
Brawlin' n Flippin'
cause my exit pipe is bottom of the hull not midway up it, also the angle that the waterbox outlet is on it goes right into my intake mani.
Also... What if.. before i teed the carbs on the return line run an individual 50-60 main jet? then tee it... No?
