ItsRixter
SoCal Wav Jumping shiznit
- Sunny Diego
I know I have extra UMI bearings somewhere if you can't find any.
Here's from my HX that I redid last season.
So frustrated! This darn UMI steering was a bitch to remove. The stainless steel bearings are not 100% stainless. The ball bearings are steel and rusted. The stainless bearing to aluminum housing bonded like a weld! I finally removed the steering unit from the hood after torching the crap out of it and using a bearing puller. However, the bottom bearing I had to tear apart. That left the outer race still stuck to the steering without much to grab onto? Any ideas?
Use a mig welder and load up the race section of the bearing that's stuck in there. Once the weld cools and shrinks it should pop right out. The shrinking will make the outer diameter smaller.
Had to do the same to mine.
I always hated that Yamaha visibility spout. Even though I disconnect it, the deck mounted end was always there, until now
First, I ground the top portion just a bit so the fill was funnel shaped. Then I used blue masking tape on the bottom to keep the fill in place.
Used a bit of Mar-Glass to fill the hole. Sand it flat after it dries
