Schmidty721
someone turf my rails
- WI
I started will all OEM hardware and then switched to longer bolts to try to grab some fresh aluminum. I think the reason it all came apart easy was the aluminum had basically turned to powder lol.
As I stated in the beginning of this threads, we worked a deal out and in my book we are good. In fact, I never even mentioned your name in this build thread.
So I got my exhaust hose figured out. Mocked everything up tonight and hooked up the battery. Total loss is working (for now haha) and did a quick compression check on the engine and spot on 190 PSI both holes. That was a relief. Just need to wait for the extended throttle cable, plumb the fuel lines and finish the water routing and hopefully she'll be ready for some testing.
