F
Freestyleriverrat
Guest
Want to get rid of the factory box????
Maybe, I need to test this set up first
where did you pick up that box?? I like the look and one of the main things a water box does is keep the water from backflowing into the exhaust.
what do you think happens if you run straight exhaust, no box? How loud will that be? like, ridiculous? any problems with backpressure if you dont have one?
hey rat, how far up can you go with your 650 bolt-ons? I've got a few 650 parts I'd like to use on an upgraded engine also. my 650 needs a 701 or a 760 in it too.
my square is a 650 ( I think it's the 61x cases), it has coffman pipe and mani, some wierd aftermarket single 46 intake ( no name). I think the B pipe is way bigger than this pipe, I'm just wondering if they will interchange up to 701/760.
I'm eventually going to put an 800+ in this thing.
I bet it is 6m6 cases, they look very similar to the 650 cases.
Please state the difference between 6m6 cases and 650 cases. :Banane01:
it's the later model 701's, right?Wad, 62t is also 701 for some years.......
whats the cases for the 800 called?
