Squarenose Project Back ON!!
F
Freestyleriverrat
Guest
:biggthumpup: Unfortunatly it won't be on by the build off (maybe if I had more time and $$ I would do the mods to put it on).........just getting a jump on next seasons little project.
F
Freestyleriverrat
Guest
Well I have paid all my bills and almost have all my parts. I will post pics after the riot ride. Hull will be back from paint this week. Any whoo.....I'm getting ancy and want to post an update :rolleyes:
Total build cost for everything after starting with a modified 650 SJ: $6980
Grand Total factoring in the starting cost of the ski ($1500): $8480
Total factoring in time and work: 100 Billion Dollars (if there was a Dr. Evil Smilie this is where he would go)
I came a little shy of my goal of building the ski for at or under the cost of a new superjet.........but it will be quite a bit more than a stock superjet so all and all it came out well financially :biggthumpup: and hopefully will be a good value ski for the $$.........BTW that total is what you will see at the Riot Ride, not including the Lamey PV cylinder for next season.
F
Freestyleriverrat
Guest
Motor is now fully assembled :arms: Pics will follow soon....just keepin the thread going........still no hull, painter wants anouther week :banghead: Just organizing stuff in one comprehensive list so you guys don't have to flip through pages.
Complete Motor Mods List
Block
-Jr. Magoo's FS Ported 61X cylinder (82.5mm bore)
-Wiesco forged pistons
-Ported 62T cases, epoxy filled and preclearanced for a Lamey cylinder (work by Jr. Magoos)
-ADA girdled Head w/ 33cc domes making 190psi on each cylinder
-New Hot Rods Crankshaft (Standard Stroke)
-All new seals, gaskets ect...
Intake
-Stock 44mm carbs (choke removed)
*Blasted and new epoxy coating applied by JSS
*Completly disassembled, cleaned, new seals and gaskets installed.
*JSS SS screws internal and external
*JSS Billit mixture knobs (high and low)
*PJS Billit throttle wheel
* Re-Jetted to Jr. Magoos Specs (110 M, 117.5 P, 2.0 n/s, 95g)
*Shafts properly shimmed to eliminate play
*Mounted to R&D manifold and custom cut linkage couple installed
-R&R Jet-tec reed spacer
-R&D intake manifold
-1st gen V-force reeds w/ carbon petals
-WPS intake adapters
-Prok flame arrestors and prefilters
Exhaust
-Factory B-pipe and Mod Chamber
-New water injection screws by PD
-Manifold port matched to cylinder and headpipe
-Water bypass kit by Protec (4mm pisser)
-Jetworks Flow Control Valve
-3mm restrictor to stinger
-Factor Pipe water box
-Modified Blowsion Front Exhaust Outlet
Electrical
-Lightened stock 6m6 flywheel (pro-tec)
-Stator rebuilt by JSS
-JSS SS laser cut stator washers
-Stock timing
-MSD Enhancer
-JSS modified OEM coil w/ new wires, MSD boots and retainers
Pump and Handling
-Blueprinted Pump vein section
-13/17 Solas COncord Impeller
-Wamiltons Stubby Cone
-Bored reduction nozzel to 83.75mm
-Worx 201 intake grate
-Carbon 24/7 D-cut ride plate
-Modified Pro-tec trim system w/ extended steering nozzel
-New midshaft, bearing housing and bearings
-Riva Yamaha Billit couplers and new dampner
-All new OEM motor mounts
-Dual Cooling
Hull mods will be listed later..............
F
Freestyleriverrat
Guest
Pump pics.......
F
Freestyleriverrat
Guest
I am slowly but surly going to post pics and descriptions (before assembly) of the mods to the hull. It is nothing secret or anything but it is just stuff that maybe a person that rides a square often would notice and others may not. This way for those of you that come to the Riot Ride you will know what all is done to the boat.
Hull Mods..............Footholds
The X-holds by Waterdawg Kustoms...................what can I say, these thing are bad ass :woot: . Exactly what I was looking for in a foot hold but time will tell how I like them on the water. I have run 24/7 holds and those were nice but my feet were in at an angle which I did not really like and you could not really lock you anckles in them. I ran Cylones last year and it did not wrap around the top of my foot that well. I achually had to remove turf just to get my foot in there, even then it was tight......Malone must be a small guy. I wear size 10 1/2 and shoes when I ride so I needed something larger and these hold are definatly that. Totally wraps around my foot and locks my anckles in there as well so my feet are not at an weird angle. Once turf and foam is on there they will be perfect!!! Very pleased thus far.
:biggthumpup: :biggthumpup: :biggthumpup: :biggthumpup: :biggthumpup:
Freestyleriverrat said:
I hear you man, I tried to see if I could paint around the turf but it was just not happening. I am just trying to get things organized so when I get the hull back I can start assembling stuff. I am still waiting on allot of parts and amhelping Mack on his ski while mine is in paint. I have to order turf as well but am not set on what turf to get. I need to go ahead and order that along with some foam so I can wrap this thing up and ride. So much to do, so little time and money is now getting tight. I'll send you a pic when it gets back from the painter.
i feel you on time and money.
F
Freestyleriverrat
Guest
Hull Mods..................Rear Tray Clearancing
Here you can see where the rear of the ski was clearanced for the trim system. Looks good too, breaks up the straight lines of the boat and gives a more aggressive look IMO.
F
Freestyleriverrat
Guest
Ski did not quite make the build off but I took it to Lanier to wrench on and show off what I had to date..........................More pics..........
F
Freestyleriverrat
Guest
more
F
Freestyleriverrat
Guest
more............
F
Freestyleriverrat
Guest
More pics will follow after I turf the ski.
Hull Mods​
27/7 carbon d-cut ride plate
Waterdawg X-holds
XFT Carbon/Kevlar pole
Prototype XFT squarnose bracket (still making modifications)
XFT carbon battery tray and cart style gas tank
Modfied stock hood
Reinforced nose with 3 layers of cloth: filled in the voids first with foam, flipped the hull over and glassed the nose area and pole mounting area.
XFT steering system
XFT bars
Clearanced the rear lip to accomidate the trim system
Trimmed the nose of the ski for a more streamed lined appearance
X-jet inspired rail extension
dual 24/7 scuppers out the back
dual cooling
reinforced sides of ski
1 layer of carbon/kevlar hybrid cloth under tank and battery (for looks)
F
Freestyleriverrat
Guest
After having some carb issues I finally got the ski fired up for the first time last night. Sounds great! That factory pipe water box and single front exhaust is really not that loud, has a nice deep tone to the exhaust.......kind of like a flowmaster.
I still have an issue with my coupler and midshaft so that will have to be redone at a machine shop before it hits the water.
F
Freestyleriverrat
Guest
Big Kahuna said:
So, what was the problem with the carbs?
Pop off's were sticking open for some reason. Darin blew into the tank and gas shot out through the carbs like I had nothing in there? We tested them and all appears to be OK now. Once I run it on the water hopefully everything will pan out and loosen up. JSS may have put some kind of lube in there or something that dried up and made them stick..........I don't know. Odd off the wall problem to have? :rolleyes:
F
Freestyleriverrat
Guest
Since this Bracket is a prototye I am making mods to it and Sergio is sending me those new parts so we can get it right. One modification I am making is dropping the pole pivot point down 4mm. That should bring that pole down a hair and get it to sit even nicer than it does right now.
I had allot of guys at Lanier comment on how nice the XFT pole looks on the squarenose SJ. I totally agree!!! :biggthumpup: It does not look like a retro fitted pole but rather looks like it was made specifically for the squarenose SJ hull. Below is a side by side compariosn showning both poles and a before and after pic of the build.
accbr
addicted
Lexington, KY
Paint job looks really good. I like the way you painted the handlepole area on the hood black. Nice touch. Motor looks awesome too.
