Super Jet Starting at 'Square' One
CRJ
Hibernating
Toronto
haha i remember seeing that ski. i offered to buy that head. usually when theres a A/M head, the motor is usually taken care of pretty well. is it missing anything that you can see?
Droste14
Be About It!
Wichita, KS
The guy that bought it from me before my friend bought it didn't cover the intake and exhaust ports on the motor when it was stored
Sent from my SCH-I545 using Tapatalk
TontoM3
Manager of Gnar Shredding activities
Sorry but it has water haha
I'm going to pretend you didn't say that and then be really surprised when it's rusty. lol
I have dinner plans here in 30 so I'll have to continue the tear down later tonight.
I have also realized that I have only taken a 2 hour nap between 6am Wednesday and right now. might need some coffee but damn I'm dedicated!
CRJ
Hibernating
Toronto
im still waiting for the day someone drops a 900+ in a SN with a good pump. i wanna see the results.
so whats you plan, run the motor thats there?
TontoM3
So yeah there is water in the engine. But nothing is rusty because it's mixed with oil, so it has like a slime in places. Anyone ever see this? Also that head is brand new it doesn't even have a water spot in the water jacket.
So what comp is 35cc in a Yamaha? Also here is the engine spec
Someone tell me what in working with
Roseand
The Weaponizer
Wisconsin
I wouldn't run a crank that's been sitting in water even if there's oil mixed in with it lol. Not worth the risk. 35 cc domes, depending on your elevation, usually run near 185 PSI I believe.
TontoM3
Gracias! I do t really know what compression ratio is yet but I am at 650 above sea level so what octane usually doEs that require?
Yeah I'm not using the crank, that's a rookie move. How would You go about cleaning the cases? My plan was to clean as well as possible and then spray some oil on it to keep it from surface rust.
Roseand
The Weaponizer
Wisconsin
Can still use pump gas, premium 93 octane. I'm not sure about cleaning the cases. Someone else will chime in about that.
They're aluminum, so they won't rust. If you've got rust on them, it's from the crank.
CRJ
Hibernating
Toronto
you should get around 170-180psi, and running 91 octane will be fine. if your over 190psi, 93+ is required. that head is brand new for sure!
for the cases i use a razor blade to clean the surfaces and brake cleaner to clean the actual cases inside and out. a spray of WD 40 will keep them clean but if they are indoors they wont corrode.
grab a jetmaniac crank. they are like $200 for a rebuilt brand new bearing crank. id also suggest him for seals. run only OEM crank seals
grab a jetmaniac crank. they are like $200 for a rebuilt brand new bearing crank. id also suggest him for seals. run only OEM crank seals[/QUOTE]
JM crank is $249 shipped and it's a $35 credit if you send him your old one I believe. JM is your go to parts guy for sure for everything you will need to rebuild that bad boy!
TontoM3
Awesome thanks guys. I'll be hitting up jet maniac for some goodies that's for sure. Reeds and cages looked new almost which was weird. Haven't opened the carbs yet but I'm assuming more of the same. I opened the stator cover and that was time capsule clean in there.
CRJ
Hibernating
Toronto
hold the reeds up to a light and look from the inside. if you see light, grab a new set to be safe.
my correction on the cranks, they are 249, 290 to us canadians. JetManiac was fast and on time with my order. something some people need to work on! Id buy from him again any time.
whats your pump plans?
