Custom/Hybrid Stunt hull build
Sanoman
AbouttoKrash
NE Tenn
sure do. Im going to spray mine with scotch guard first. Then if it ever gets muddy people say to use bleach on it since its white and itll come right off.
Man brock,that sounds lke a good idea with the scotchgard.l have purple mats on my fx1 that l'm forever cleaning.l give that a try.
Sanoman
AbouttoKrash
NE Tenn
Count me out on that one.l think just chad is the only previous builder.Above all the crap that l went thru to get it done,the experiance was awesome.
Next lesson,no more highroller poop................
Pablo
sqeez bth levrs & lean bk
georgia
I had white turf accents on my first ski and it was fairly easy to keep clean. I live on a lake that for the most part has water that'll stain things browish. I never really got any georgia red clay on my ski/turf, but when I'd start a new season I'd put a 50/50 mix of bleach and tap water in a spray bottle and mist it down and let the sunshine do the rest. Took maybe a 1/2 hour for the sun to work it's magic and it'd be like new again...of course I'd rinse it real well after the sunshine.
Sanoman
AbouttoKrash
NE Tenn
I've done alot of banging on Dan/Highroller hulls, but with the time and effort you've put in here you're gonna have a very nice setup. Waternut has done a ton of work and tinkering and has his to near "dialed-in" status. I def think that these hulls have lots of potential...you just have to be patient. Between you, Waternut, NCbrock, and Chris most if not all the bugs seemed to have been figured out. Kudos to all you guys for being detailed and persistant. Ski's gonna look sick in the green. What color turf?
Meant to say earlier thanks for the comments.lf it wasn't for chad,l would have had a lot of problems and probably had a lot more trouble.
Sanoman
AbouttoKrash
NE Tenn
Thought l would show a few pics of "The Green Hornet".Been working on a lot of items and should be ready to set the motor in by tues or wed.
l want to really thank Jetmaniac for getting me a steering cable out on friday,so l could have it on Sat.The reason for getting it quickly was it had to go in before l could do much more.THANKS CHRIS!!!
Waternut
Customizing addict
Macon, GA
Color looks really good man. Nice and shiney too. I like that low profile pole as well.
I'm running a SN steering cable ncbrock so you shouldn't have any issues.
McDog
Other Administrator
Staff member
South Florida
I like the white turf idea too. The ski looks kinda like a fx1 with the pole bracket mounted on the outside. The two tone turf in black and silver would look good too. I'm going with that when McBOB needs returfing.
Pablo
georgia
I second that with the two tone turf. I'd hit that thing with white turf on the tray floor and gunwhales and use black as an accent color for the front and the insides of the footholds...my .02.
Slick azz paint/body work. Real nice job.
Sanoman
AbouttoKrash
NE Tenn
this is AWESOME I love that color. Are those home-made hood straps? Also I have a sn sterring cable you think that would work?
No.it is a Jetmaniac Braap strap.You can make one yourself,but Chris makes it easy.l used a couple of brass grommets and then used wakeboard screws to install.
Thanks for the comments.l did a lot of work to the stunt,but l suck at paint and body work.The credit goes to some buddys of mine that were in the business.
Must have got that idea from my fx1! And that would be awesome with two tone turf.May have to really think about that.
