SuperFreak Carbon Topdeck conversion (Finnished)
Sanoman
AbouttoKrash
NE Tenn
The xmetal pole is so clean looking.l only wish mine would have worked out.Have you used a pole before w/o a bolt and a spring?
Ok so my fiance has had the camera for a couple days so there are some steps left out. But, I have assembled my 735 jetmaniac/blue motor (installed the stator, #0 super light 62t flywheel, bendix, carbs, ect.) Also installed the pump and midshaft today and got it all alligned. Finnished running new steering, new throttle, new trim cables. Put my superfreak carbon waterbox in. Built my ebox with a new jss coil , msd enhancer, OCD solutions tidy bilge , ect. And im sure there are other odds and ends that i forgot but all of this has been done in 2 days :) . I took friday off work to build and hoping that i will come close to finnishing tommorow. Almost all parts on this build are thanks too jetmaniac, Clean parts , great service.
Alright so first break in was today!!! thanks for all the help lucas. Should be threw the first tank by tomorrow. Then one more tank . Then balls to the wall at mc dogs!
The power plant...
new sticker
I got my motor broken in today thanks to jetmaniac for letting me ride for 4 hours. The ski feels super light a responsive.
The motor is a 735 blue motor, dual stock 38's, #zero 3.08 lbs mint flywheel, ada head 33cc domes,b pipe lmtd chamber, superfreak carbon waterbox,cold fusion couplers (not installed yet). Im running a 14/19 big hub with a wet wolf and 2 washers behind it. It seems to work really well with the setup, i wont know for sure until its fully tuned. I want to thank everyone that helped me with this build. I must have called lucampits, blue, augustaf, and jetmaniac atleast 25 times each. Also thanks for anyone that got me parts, Mostly jetmaniac for parts and all his pateience with me. I will be at mcdogs on sat and cannot wait !!
JetManiac
Stoked
Vendor Account
orlando
Ski looks really nice. Corey has a nice 'lightweight and brappy' relatively low cost build/ski
Looks like the 4 superfreak posse' is rolling to the mcdog freeride with 2 more riders flying 'Aircraftsalz Air' with carbon Rickter on board. The carbon content is going up in Georgia this weekend.
McDog
Other Administrator
Staff member
South Florida
I bet you could do it with my full ballast boat setup wake. I turn the boat and make a setup wake that is HUGE.
maybe if i was skilled but i have only tried a backflip once and it was on lucas's surf ski on flat water, the outcome was not good i fell out of the footholds and the pole went into my stomach. We will see though i just went and bought a helmet and i got shoes also today.
Those are scary. I had my dad do a U turn with our supra last summer with full ballast on I think it was a total of 2500 lbs or something close and it was HUGE, I was scared to hit it
