SuperFreak Carbon Topdeck conversion (Finnished)
Cannibal
Tasty Human
Summit Lake, WA
Very nice build. You really have me thinking here about this square hull I have and what I could build with it.
I've done the silicone thing as well. I used some GE stuff from home depot. It peels right back off. I just keep peeling it off and putting it down when it comes up, but there's probably some better stuff than what I used. Maybe some black 5200, definitely harder than silicone though? I'd recommend running a tape line on both sides where you don't want the silicone to smear to. Take care and form the tape in the grooves of the turf and you will have a nice finished product.
I just weighed my hull and i have to say im pretty happy with the weight. 100lbs. That is hull,hood,nose piece. painted, turfed, pump shoe, brap strap, ebox mounts, and all mounting hardware for gas tank / water box installed, and hood seal. On a side note this is not just a flatwater hull. This was made for surf also, so while weight was an issue, so was stregnth.
ok so i got the pole in and i mounted the bracket. Also cut the nose piece to fit how far forward i put my bracket. Hopefully i will finnish painting my nosepiece and hood soon now.
The raider is my mint donor ski i picked up last night. The engine carbs and electrics and motor mounts are MINT. My next project is to disassemble this and turn that motor into a jetmaniac blue motor!
yes it was off craigs list. And all of this ski will be going to good use. After, the hull may be part of a secret project because of how mint it is :). I will be disassembling it today.
engine is removed and everything looks almost new . My bendix and whole electrical system are amazing. Carbs perfect. Ext. I cant take pics because my fiance took the camera but i will later tonight.
rrp steering arrived today thanks to brian at thrust innovations! Speedy service.
Mounted it with some minor adjustments needed for it to fit on x metals pole.
