- Grand Rapids, MI
Here's a couple pics for a limit strap mounting option. Pics are in no particular order again ha!
I did almost the exact same thing on my x metal adj. pole. Used one of the three adjustment bolts.
What pole? On the carbon pole that Tem built for me, I drilled a hole near the steering stop, into the bottom of the pole. I fed the limiting rope through it and tied a knot. Burned the knot a little to make sure it doesn't come undone.
I know of one more I have been talking to that has one on order also!
Green and mean right there! Now get that thing done.Just finished my boy papp's freak![]()
Ultra plush . 25 mill tops bottom plus 16mill under heels and side of ankles 58 for the kick tail . Oooo man it's soft and locked in
So much for a water test for a few weeks.:17: l have the Solas pump problem that others are having where the driveshaft is too long.l understand that someone is working on a shorter shaft.l think that is the best solution overall.
Otherwise l am done with the build.l'll post up some pics this weekend on the tenn/georgia build thread.
View attachment 180860Just picked mine up!
Congrats Jeff!!! Stoked for you! Now hurry up and get it on the water.
Damn, you must have set your bulkhead distance up nice and tight for maximum spline engagement huh? The Solas does not work with that setup as we are finding out... sorry to hear that. It definitely set me back on getting mine together too. :crying:
I'm working on an extra-thick midshaft spacer with a shorter midshaft (FX-1) to allow me to use any pump.
