John at JSS is one of the most honest buisiness persons you will run across. Check with Parrdaddy or Madoyster, they will disagree with you.
His knowlegde and skill in what he does is what this sport needed. Checking the dip switches and the LED can be done but he would have to spend quite a bit of time to do so. He was paid to go through the system. Why didnt he?
Hell, Im sure he would do it if he could charge for the hours. Since this is your first TL there could be a few other issues you have. Once again someone tried to save money and buy a second hand piece, then when it doesn't work out and money has been paid to shine a turd it must be the skilled works fault. Bad93blaster bought an old MSD and John did his magic but its still an old MSD. John goes the distance for his customers, if you how much info he passes out then (well if you did you wouldn't need him). I feel for you and wish I had some info to help but you bought it, Jonn set it up and know you have to figure it out. You sound like you have more knowlege than the average board member so there may be some one out here who will pass on what you need. Bad luck so far, but its not JSS's fault.hmmm , JSS was paid to do a service, other than making it look pretty it does not seem that mcdog got his moneys worth
Start with the coil and the simple things first. Keep posting so we know how it goes, and maybe we as a group can throw some ideas your way and get your boat running.
