Super Jet The why would you build a sn?
you may have just inspired me to do something similar or at least something with a sn. You got a final weight on the hull? I wanted to do some major glass work on either a kawi 650sx, 300sx, or a square nose. Wanted something for rec/freestyle that would be short and custom. 650 is obviously a super cheap hull to get my hands on, but wasn't sure if a sn would be a better platform to start with, it'll cost an extra thousand though to get a sn by me compared to a 650.
I still need to get the final weight, it was just under 110 lbs just hull, but that was with everything finished exept the tray. If it was me I wouldnt mess around with a kaw, ask almost anyone and you will get the same answer.
One of the sickest builds I have ever seen on the X
Thanks man, hope it will be the crutch I need to step up my riding, cuz I here thats the only reason for making changes to a boat or buying an AM boat, just a crutch. I rode with you guys a couple times at sheldon, I had the black and green rn and the wetsuit straight out of 1994. Cant wait to see your freak in person, thats my dream ski!
It would hardly be a kawi though. it would have yami or possibly sxr pump with matching tunnel/cavity, yami powered, a/m handpole, completely chopped hull. i would start with a sn sj like you but it's gonna cost an extra 1000 to get the hull, i feel like it might be better to put that thousand into the powerplant or pump.
Schmidty721
someone turf my rails
WI
Bare SN hulls can be had for less than $200. I Mint RN hull barely brings 1k anymore
It would hardly be a kawi though. it would have yami or possibly sxr pump with matching tunnel/cavity, yami powered, a/m handpole, completely chopped hull. i would start with a sn sj like you but it's gonna cost an extra 1000 to get the hull, i feel like it might be better to put that tthousand into the powerplant or pump.
I payed 100 dollars for this hull, hood, pole, pump shoe and midshaft bearing, and I dont have to try and figure out where to put everything inside, thats why I went this way. It was more than enough work doing all that I did, couldnt imagine only being half way done now!
