Yes but a single carb should have fairly simular plug readingsNice thing about duals can adjust seperatly if needed
Sent from my QMV7A using Tapatalk
I could c that. Carry on lolYes but a single carb should have fairly simular plug readings
Cylinder was just surfaced so I'd hope not.. But that could be a possibility!Huh idk only thing I could think if the oring for the dome your having trouble with has a small leak possibly
Please explain how an internal air leak would not show on a pressure test? A leak is a leak.......Doesn't lose pressure for as long as I let it be. And ive tested it probably 3 different times within the past 10 hours of ride time. Always holds a solid 10 psi for over 20 minutes. But an internal air leak wouldn't show on a pressure tester. Pressure test just shows crank seals, base gasket, head gasket, intake gaskets, etc.
Reed cage assembly. Would leak into the cases but not flow back out through the intake maniPlease explain how an internal air leak would not show on a pressure test? A leak is a leak.......
