Time Crunch World Finals Trixstar Build
Trying to get another Trixstar finished up and the new Engine Tech 1107 motor in before Havasu. Went with a different visual carbon on this one, the more traditional twill, not the wide stuff like my first one, also used honeycomb weave in a few spots. I also modified the intake and pump area to fit a 155 pump.
Some pics:
Pablo
sqeez bth levrs & lean bk
georgia
That carbon sure is slick looking. Sano as hell. From the first hull to this one all ur work looks "spot-on."
Looking forward to hearing independent ride reports post havasu.
If you have Facebook look up E-Tech Superchargers, he also posted some stuff on here about his motor a while ago. It's a 10mm, 94mm pistons, 1107cc. Dyno numbers are showing good power ;). He also has a new Y pipe in the works that yielded excellent power gains over the PF manifold, I'm hoping he finishes up the first production Y pipe so I can have it on this motor. It all depends on time now, and it's getting short.
I have to clean up the pump area since I modified it, but the good thing is it fits the 155 pump and the intake tunnel is massive! The 2" wider RRP grate fits with a little room to spare. There won't be any issues with starving the pump here ;).
