Whoa ! I would love to see that set up for low- mid , with quick throttle response (no lag) , with the correct size turbo and intake ,can it be light switch power?
With antilag, ecu tuning it can hit like nitrous.
But draw back is you can't continually run in antilag or turbos don't live to long.
Buy my thought is to use a heat exchanger to cool turbo so extended anti lag can be used.
Or just combine turbo with nitrous hooked up to pressure switch so nitrous turns off once on boost.
On my busa motors with anti lag off I can get 22-26psi boost in neutral.
Anti lag on get up to 35psi boost in neutral.
On sleds have big turbos responding with low lag at over 8,000ft elevation.
With nitrous they hit to hard in sled
without anti lag system there def raceable.
Question for all, why doesn't anyone use nitrous?
Please don't say it kills motors, that's tuners fault not nitrous.
I have run it on many couches and it rips!
It could be the backflip button?
My SN has enough room inside for 2 4lbs bottles.
That's a weekend worth of 3 second blasts.
