TNT v2 free ride production pipe
bored&stroked
Urban redneck
AZ
So its $1125 for the system plus you need to buy a manifold and can't use a stock gas tank? I was hoping someone would make an option to the B-pipe since they all sell out so quickly, something that just bolts in and works with stock components. Sure is a beautiful pipe though!
Christian_83
Xscream
Denmark
weight numbers are in post #11
"So now there is a tunable wet pipe that makes as much power as any dry pipe on the market, is almost 20 LBS lighter then a dry pipe with water in jacket and 4.8 lbs lighter dry."
I will tell you------it just flat out works awesome! If you over heat it, it just gets hot (we tested that). Its light. With the waterbox, it works so well when you land, motor stays clean. Depending on what pipe you have, you will find missing bottom or gain more top, its a win, win.
tntsuperjet
Georgetown ca
Tnt is no longer selling the pipes retail. You will have to go through one of our dealers. We are finishing up some new projects and trying to get first run done before havasu.
BLOWSION,TPE, Thrust.
Outside USA, AJSP, ElProfessor
tntsuperjet
Georgetown ca
Over 30 chambers sold in last month. From 701 to extreme 1400, not one person hasn't said wow.
Look for us at havasu. As we will have the v2pro series pipe in the tigercraft with 964 engine.
And at rip N Ride at pismo.
You can demo the tigercraft sv1 with EFI on a TPE 964
964Chris
FREEdumb obtained
TEXAS
Heard that was a really nice build ;)
