We posted a price before the production runs where complete and that price is not right.
Chamber 850.00
Water box 275.00
It's the best flowing quietest muffler on the market for free ride not to mention the only water box for free ride that pays attention to water loading.
If the box design is open baffle it will be inconsistent depending if the tail is bellow the water or above the water.
Have the exhaust plugged by water causes rich condition.
And when the boat is above water line it goes lean. So you end up having to constantly do hard blips on throttle to unload the water to keep your jetting stable.
Also the pipe has the same type low end grunt as a RRP but it revs as hard or harder then the power factor. So you can have both in one pipe. It also is very sensitive to temp so you can really tune it to your needs. Keep it cold and it rips off the bottom. Let it get hot and it will rev 77-7800rpm.
Peak rpm cold 6950, hot 7800
So this pipe will work really good with a wide variety of engine pump packages
