Long as it wasn't ever run low on oil it should be good. Spindle bearings are an easy fix but some people never do and wind up destroying belts and everything aha
Well, I spoke too soon. I only pulled one spindle the first night and it came apart easily. The second---not so much, wow. Heat, 8lb maul, penetrating oil, more heat, puller, even more heat, impact gun, and more heat finally got the pulley off then I had to cut one bearing off with a dremel. Unfortunately with so much pressure, the threads on the spindle shaft are jacked up somewhat. I'm hoping to clean the threads up with the dremel so I can at least impact the nut on.
My Snapper walk behind I used to have was a piece of cake to do the spindles on, the pulleys had a puller built in to them and came off in 2 minutes each.
