Highroller
X-
- Sarasota, Florida
Anyone else? Curious to see everyone's setup!
im going the same pump and eric reccomended a 13/18 for mine with a very similar setup*1021cc, 4 mm PHP crank (standard weight), pump gas
*B-Pipe Mod chamber, ported out to 50mm
*H2O designs waterbox
*48 Novi carbs, V-Force 2, Riva Intake
*H2O Designs Torrent 148 pump
*Don't have a prop yet! Not sure what to get.
*MSD Digi Pro Total Loss
Heck yeah. Were you running pump gas on the 964?Stoked for you! Sending my 964 in for an upgrade this winter. 4 mm lightweight crank and a slight bump in compression. Can't wait for spring!
Yes, but even with his smallest domes I was at 176 psi at 5,000' elevation. So he's going to bump it a little and still keep me on pump gas. Stoke is high!Heck yeah. Were you running pump gas on the 964?
Sent from my VS980 4G
Please don't neuter that motor with a bpipe! Get a PFP or a RRP!!So I have an 1105cc on 48mms with 155mm mag, b pipe and MSD ignition all going in an overall hull (flatwater yet to be released)
slightly different with the B pipe but should be sick once set up
View attachment 268033 View attachment 268034 View attachment 268035 View attachment 268036
Budget is blown for the build, will have to wait for a used PFP to come up, which won't be any time soon they're not too common over here, we will make it work.Please don't neuter that motor with a bpipe! Get a PFP or a RRP!!
