- Marion, Ohio
I just injected the front end of the pipe. The stinger just has the flow control valve on it turned down enough to keep the waterbox nice and hot.
Can you post up a picture of your pipe set up so I can understand it more since I currently dont own a pfp yet and am confused a bit . Thanks in advanceSounds like a good set up. Nicely done! After getting a RRP and having a PFP on my sons ski, that's how I'd run it.
I'll post some up when I get on the computer. I've got some now on my phone of the RRP, but I'd like to get some of a PFP too, so you can see the different water routing. But for the most part it's pretty straight forward when you see one. Pressure test the chamber to make sure it doesn't have any leaks. Cap off the outer jacket of the pipe. Drill and tap in a spray bar or something like it in the ex man (roughly same location as RRP spray bar). Keep the water running to the stinger in front of the water box. Adjust the jet in the stinger to keep the box hot like posted above. And a 70 jet is probably super close, because my son ran a 90 and it could still be dried out more when running the dry setup. So adding water from the spray bar should cool it down a tad more. We're going to set it up on the kids ski for sure. Never know til you try!
That's smaller than anything we have ever tested. Our test engine was murdering a 13/18 large hub.Random question? Hoping someone can help.
Has anyone run a 11/17 large hub with a 964? I currently run a 14/19 large hub which is great. Just wondering if I will get more punch from the 11/17 or just cavitation? Appreciate the info![]()
You guys are doing the water injection and also injecting water at the stinger? Have you tried just injecting at the spray bar? I'm just wondering because when I ran mine wet I only injected water at the spray bar, I'm just wondering if injecting at the stinger makes a difference?
I just ordered some from JetManiacWhat's the opposite of "spinning" your prop called? chugging?, 'cause that's how it felt on my C75 16/20, before this mod was made. The dry 2 wet conversion cleaned that up, right where it counts.
Who carries #40? or #30 (since we're tinkering)
