TPE MOTOR SETUP's - list your package
I learned that the 1105 with the light weight PHP crank needs a slightly bigger pilot. I'm at a 130 now and have the low speed screw past 1 1\2. I'm going to try a 132.5 and see if I can't get it closer. I do not like having screws on a full spectrum any more than 1 full turn. A conversation with Ed and he will explain why.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
I bring my timing on way sooner. like 1800 rpm its at full 32 degree advance.
Sent from my SAMSUNG-SM-T217A using Tapatalk
This is the very latest :)
Sent from my GT-I9505 using Tapatalk
McDog
Other Administrator
Staff member
South Florida
I'm going to try this. I'm hoping the b curve will tame the motor a good bit for surf. I may retard it even more. We will see.
I received my TPE 964 two weeks ago and dropped it into a Krash JB1 hull. Really impressed with the power and that was running it rich on its first tank (we are in winter at the moment so limited chances to ride)
Freeride Surf Setup:
Krash JB1 glass lay up
B pipe bored to 50mm
lightened flywheel
MSD enhancer
OEM coil
46 mikuni (125 low, 125 High, 22 pop off)
JSA crank
ADA coupler
14/19 skat large hub
12 vein 144mm pump
Custom alloy battery tray
Custom alloy air box tray
RRP billet pole
ATP water box
Cold fusion mounts
964Chris
FREEdumb obtained
TEXAS
that air box is fine for 46's. the singles not so much. It seemed rich because he was running it rick for break in.
Byeai
"Cheetos-Man"
Melbourne FL
I thought some engine builder said it's hard to break in a nikasiled motor because of something I don't remember the reason
That looks like an air box for oem 38's that has been modded.
I was running it rich for breaking the engine in.
We make custom alloy base plates to suite any type/setup of carbies so that the OEM airbox can be used with the mesh filters (only one mesh not three). Check out the pics. We can make them out of plastic or alloy, we can also make plastic trumpets. If you are interested let us know, the more we make the cheaper it is.
What octane and RON pump gas? 91-93-98, fuel octane and quality are usually relative to location, so the term "pump" gas can be very general and in some cases misleading.
Very impressive, more so if 91.
Pablo
sqeez bth levrs & lean bk
georgia
Nice stuff
