Trinity Composites
Lightweight Evolution
- Palm Bay, FL
The stockers weigh between 165-175 lbs. Jonnys ski weighs 130 lbs with the same amount of hardware as a stocker. We saved at least 35 lbs on the upper conversion. A stock hood weighs around 24 lbs. The race hood weighs 9 lbs for aIt took a bit of re-reading, that weight is just the hull correct?
What is the weight savings when you factor in the hood also?
difference of 15 lbs. Total I took 50 lbs off the stock weight.
