accbr
addicted
- Lexington, KY
I currently have a ported 61x motor running 180 compression, 46mm carb, lightened flywheel, cutback concord 13/16, fs cone, and a stock cdi with no rev limiter. I'll be getting a b-pipe too.
What would give the most bang for the buck? Upgrading to 62t cases with single carb manifold or total loss ignition? Seems like these go for about the same amount if you can find them used. I don't want to run dual carbs, and I've read all the threads about them. I know total loss ignitions aren't simple either. Just curious what most people would recommend.
edit: looking for more bottom end.
