Custom/Hybrid WDK ROK-R Build
DarkWater
Down Side Up
waterford, MI
Yes the hull without the hood is 79 pounds.
It will be interesting to get it on the water and see what the hull is all about. It could go either way. Hopefully I can use this thread to help answer everybodies questions about the ROK-R.
Is that 90 lbs with turf, plumbing, intake grate, ride plate, pump shoe, pole bracket latches and various hardware?
If so that's still pretty light.
Sanoman
AbouttoKrash
NE Tenn
4 Seasons l noticed you have the same battery holder that my Rok had.Make sure you put some grease or some kind of rust protector on the threaded rods.Mine got real rusty after a year.
Decided to get started on the build, it's almost spring :) Just got my Solas 12 Mag pump in, just waiting for my thrust trim system so I can get it shimmed and installed. Should be ordering a X-metal competition length pole in the next few days unless anyone has a used one they're looking to sell?
CD155MX
Squirrel!!!
Alta Loma, CA
I have no idea what the X-metal competition length is, but from the few min I had on the hull that WDK had at the finals I can tell you that you're going to want that pole super short.
X Metal poles
LengthAdjustability
shortestlongestminmax
long33.5"36.5"-5-2
medium31.5"34.5"-7-4
competition27.5"30.5"-11-8
<tbody>
</tbody>
CD155MX
Squirrel!!!
Alta Loma, CA
It had the short plate on it. The hull seemed fun. The motor had a massive exhaust leak according to Jeff when I rode it and was lacking all kinds of power. It was hard to ride with the power as it was. Working with the horribly running motor was a pain, but the hull seemed capable of putting a smile on anyone face that wanted to have a fun playful ski.
ph1lthy11y
Cummins hauls my ski to the water
california
Pablo
sqeez bth levrs & lean bk
georgia
Never had a drop of foam in my freak for 3 years. It does have sealed chambers of air under the tray but I bet would stay afloat long with the hood popped loose. Don't sweat it.
The ROK-R's rear is not sealed, though. It's open from the front all the way to the back. If it sinks, it's going down.
Well I won't sweat it to much then. With the way our snowpack is this year are reservoirs are gonna be waist deep anyway :)
Thanks for the compliment burton391, I've been watching your squatch build as well, looking good.
Just got off the phone with Rick at Xscream and ordered a competition length pole. They are finishing up a batch today and sending them off to powdercoat tomorrow, so should ship in 2 weeks. Can't wait to get it.
my xft was the same way no foam in the rear other than the upper side rails i think every hull should be built without foam. they are way lighter that way and no place to store water. when i went from xft to rok. it was like there was a ton of bricks under the tray i haated it. one thing i like about the rokr is that there isnt any foam or a place to store water. that thing will never sink and if it dose make sure to kill the engine before it goes down and it will be good as new. in mi freshwater lakes ive only seen a couple skis almost sink and were both operator error for sure. i wouldnt worry one bit.
I talked to jeff (wdk) and he suggested the pole lengh at 27 inches from pivot to pivot. I hope that helps you out a bit. nice build!
Thanks. Got my competition length pole from xmetal last week. 27.5 inches at its shortest so hopefully that works well. Should have the majority of my other parts in this week so I will be updating the thread soon. Hope to be on the water in a couple weeks.
Piratelife forgot to mention that the neither the pump nor the motor required any shims at all. Pretty nice to have a hull go together like that. I've had 3 AM hulls and the WDK I currently have is the only one that is running no shims and neither is Piratelifes. BOB-aint even gonna start, Trinity has a few.
