Vumad
Super Hero, with a cape!
- St. Pete, FL
Did you plane all those so that they were all the exact same thickness?
Unfortunately I did not. I tried to find a planer but was unable to locate anyone with one, couldn't find a business to do them, and didn't want to spend $350 on a planer. I could plane them down in the future if I ever obtained access to a planer. It'd be no big deal to router and stain them again. Most of the time went to box so it's no big deal. I did play the game and it played fine.
Looks yummy. Bring that pot to Hugo today for a sampleI fab up'ed some shrimp gumbo up today! View attachment 295184
I wouldn't think there would be enough variation from board to board to worry about planing. I worked in lumber mills for years, every board goes through a planer that holds much better tolerances than anything you will find in even the best woodworking shops.
If you have ever frames or built a house you know not even all the same grade is the same. Some good some bad in my experience. Also I think we are taking the Jenna a little too far. It looks awesome and if it plays well then it's good to go. You've given me an ideas about a slightly smaller version from aluminum extrusion 2x4 just don't know it that would sell or not.
Old rings (heartwood), closest to the pith without it are the most desired as the wood dries/shrinks more consistently. Also how the wood was milled makes a huge difference, plain, quarter vs. rift sawn. Almost all s4 box store wood is plain sawn which is the least preferred. Most common as they get more from a tree though.
Nice job but I'm surprised you didn't run through a jointer then a planer to make uniform as boards are not the same thickness throughout varies, also gets rid of cups and twists with may or may not be evident in short pieces.
Keep us posted if you notice any issues with the play due to any of the above.
