So I got my total loss fly wheel (stock that's gutted and lighten for the zealtronic ignition) and some 140 main jets. Hopfully this will help dial it in. I need to cut the water more to my b pipe. Still wasn't running super hot this past weekend. If 140s don't help, do I bump the lows? I'll need to reread all this thread again to try reverse jetting. Seems like you would go through a lot of base gaskets if your taking off the carbs or have a chance of ripping the mesh screen on the carb to get to the jets.
Are you running the stock 760 intake? If so, did you fill the crossover?
If not, you need to do that.
You can remove the jet cover 1000 times and not wreck the diaphgram or gasket. Also, if you grease the carb base gasket you can get away with reusing it but the oem gaskets arent real expensive and a few bucks on gaskets are worth a better tuned ski for sure.
Also, the guys that gave you the jetting recommendations gave you it for a reason. They are a better starting point. Make sure your crossover is filled. That will drastically change your tuning and those specs are based on having it filled.
