- Ft. Dix, NJ
I always wonder though if super cold water is bad for the motor. I mean that extream cold going into hot cases seems like something might crack
Anyone ever run into problems before?
I'm wondering the same thing. Anyone?
I'd like to see pictures of all the pissers people are doing. I'd like to re rout my sj to where i can see it
Thank you, I will put that on the list, and is it really technically called a pi$$er?
its a good idea to warm up your motor i usually give it a little more time when its reallly cold. I have never had a problem
here is my adjustable flow for engine temps.
and the handle bar pissers for my hands
If the water or air temp is under 80 I wouldn't risk it, it just isn't worth the risk of hypothermia .
X2.. I ride Memorial to Labor Day and that is pushing it sometimes. I had to wear a spring suite once and did not enjoy myself. If the wife can't wear a bikini it's too cold to be out there.....
You guys are hardcore/crazy!
When the water freezes both my throttle cable and my lanyard post.
