Idok
F1pro
- Nations oldest muthaF+++kin city
you shouldve known better than to put a TDR box in your ski..... EVER.... at:
Royal Flush did it.....I just never changed it :stooges:
Right is Right. Lefties should be drowned in shallow daytona breaks. :unitedstates:
This sucks. I really wanted to run an XMetal Waterbox with rear only for my local lake, than front and rear when I'm out on the big water.
I was thinking a quick removable T would be better than a plug. I'd have to fab something up and cut the T from XMetal off, than use silicone couplers and hoseclamps.
I don't mind changing it up although you'd have to pull the tank, etc.
The plug thing seems too easily to pop off.
That is your problem, Roll Left and you will get it, it all about the rotational mass of the crank.......... when your roll right the crank is working against you........
U cant be serious about this???????:sad:
can you order the xmetal box for rear exit only?
Just get the regular and buy a rubber pipe cap from Home Depot. That's what Pat recommended to me and it's held up perfect for 30+ hours so far. Do it that way and you'll have the option for dual later.....or if you want to sell it.
just a regular rubber cap? Doesn't leak water or exhaust?
