bulkhead was made today. it was wetted out with 7 layers of 12oz biaxial cloth. A cardboard templete was made and then the glass was fitted. Lots of trial and error. I also started trimming up the waterdawg interior plate. My goal is to leave the plate mostly intact because Jeff has already done all the hard work by placing the motor mount holes, drive bearing hole, etc in the right place. He pre-drilled my holes with his jig so I don't want to alter the alignment. All I have to do is glue the plate in the right spot in the hull to keep everything in alignment. Eventually the plate and bulkhead will be glued to the hull. All gaps will be glassed over then covered with texilium for appearance.
