We fitted the bulkhead today and decided on exhaust placement, drain placement.
I went with a xft scupper, it seals very nice. I placed it inside the pump area because the back of the hull angle is too steep for proper sealing, I also think they last longer since they are more protected in there.
My exhaust is high quality pvc and duct tape. Lightweight and cost effective.
Not really. Its a easy way to mock up the angles I need. I took it and some aluminum pipe to the welder so he would know what i needed. I have angles in it to clear the footholds and exit at same angle as the rear of the hull (downward) to help with the noise of my motor.
Last pic is the outside glassing to cover my attached end pieces. Lots of sanding left
