550headache
tobacco grower
- tobacco valley
Glad it worked well after all that waiting!
Sent from my iPad using Tapatalk
If you don’t currently have padding under your water box that could definitely be causing vibration. I slid a chunk of cork and rubber gasket maker under mine and it helped some. I also plan to turf the area so I’ll keep you posted.I had a bad vibration on my Yamasaki.. first thing i did was cut the battery box out on the carb side front corner where one of the bed plate bolts hits it. Helped, but still there. I dented my 650sx pipe with a mallet to clear where it was touching the motor….still there. It’s a lot better but i notice it. It’s just offf idle then clears up. Next thing I’m going to do is remove the all metal super trap water box and turf under and behind it. Hopefully that’s it! If not I’m going to pull my brand new Jetnetics flywheel off and put the stock on back on.
I REALLY hope its the water box!
Here is how I did mine, its wrapped in turf, wedged with a shaved yoga block, and strapped using a yamaha strap clip and seadoo waterbox strap. Doesn't leave room for a front fuel fill though.If you don’t currently have padding under your water box that could definitely be causing vibration. I slid a chunk of cork and rubber gasket maker under mine and it helped some. I also plan to turf the area so I’ll keep you posted.
Good idea on the dry box placement, I have been trying to figure out where to put one.
I have been really happy with all my wax stuff, well made and reasonably priced.
Sean
My Yamasaki had the same vibration just off idle… chased everything but nothing helpedOnly problem i have with them there in Australia and it takes a little longer for your parts..
I ordered a TDR water box from vintage jet ski in June and still haven’t gotten it! Also ordered a Custom Matt kit a month ago from jet trim. Hoped to have it on before the riding season ends. That’s not happening. Sucks!
Did anyone else try this fix?My Yamasaki had the same vibration just off idle… chased everything but nothing helped
Finally went to stock SJ motor mounts and machined bed plate to fit and all is great!
FPP mod pipe fits without mods or a blistered hull and pulls hard!
Hope you finished yours up…
Ski is smooth through out the revs
That is an understatement!That Water looks Cold!
