- Coeur d'Alene Idaho
Congratulations on your wins!!!
What are those rear sponsons and do you recommend them? Or would you suggest something else?
Are you left handed?
You're 100 lbs or so lighter than a sxr and at least 50 lbs lighter than a superjet haha. The key here is clean water, once it starts chopping up, I bet they run you back down. Still cool to get the win. Sounds like you got a. Good enough lead from the start t9 hold them off for the rest. I still.had the 550 pump on my ski with the 750 engine and could hang with the sjs and sxrs only in smooth water. Once the chop started, they would catch right back up hahaShe legitimately walks away from lites skis in clean water!
I also pulled the RHASS mounts from my ski. The vibration from them was bad.So Ill speak up because I am someone who is not happy with their rhaas mounts for 2 reasons.
1. I bought them because they "had" lifetime warranty, which is no longer offered and I have heard you dont get grandfathered in.
2. Urethane mounts just vibrate. I should have known this because I once replaced mounts in my street/track car to urethane and everything started vibrating and some things shaking loose. So the rhaas SJ mounts I have, also vibrate like crazy despite being anal about making sure everything was aligned with feeler gauges in multiple directions. Its just the nature of urethane mounts.
Hopefully they are replaceable with stock SJ rubber mounts (now im talking the 550 conversion mounts).
