Loving the look and fit of my tank in my Predator. All the rest look homemade compared to yours!
Your batteries going to fall out, FYIV2 bot
5 gallon
Rivman, is that the 5gal you have there with the PFP?Yeah, mine came off a couple times with my B-Pipe, but with the PFP it's way too close to the motor. The blocks should keep the tank away from it, but I'm going to remove the tube to be on the safe side.
-Rob
That sounds like a bit of an issueI did. The sight tube is in a bad spot. Mine came off like 5 times resulting in a mess.
Sent from my SM-G925V using Tapatalk
Sent from my LG-F350K using Tapatalk
