750 SX Freestyle build
N3vrSat1sfied
Military Member
Fort Worth, TX
Hood is almost done. the Handhold domes are in the liner is back in just some more sanding and shaping of the "dash part" and there is no more cock drawings. also notice the flat entry into the handhold, no ridge like the stock hood has
The inside was all sanded with 36 grit and we filled a few low spots and started laying glass i did one/two layers on the sides. there will be neon green carbon fiber going in next. The nose has 3 layers in it.
PS this was my first time laying glass usally travis does it but he had his ski to do and i had watched him enough i figured i would go for it
tbaer
USMC
BEAUFORT SC
not sure the weight is is just that cheapo stuff from auto zone. Don't worry we are laying some carbon/kevlar ove rthe top of it so it will be strong.
S*G
Shred the GNAR
Brighton MI
haha just so you know im using your wright up as a basis for when I go for my first ski build up.
Lookin good though :Banane09:
N3vrSat1sfied
Military Member
Fort Worth, TX
Thanks, just use two part foam! my only regret so far!
Maybe the carbon fiber will be in this weekend and the ski will be completly sanded.
N3vrSat1sfied
Military Member
Fort Worth, TX
well i was gonna lay the fiber tomorrow (or today for you people that work normall day shift, i always say tomorrow untill i go to bed) and try to finish sanding but i had a minor set back today at work as i spent a few hours at the hospitol. I am gonna try and get a good nights rest and see how i feel in the morning and hopefully i can get some work done
tbaer
USMC
BEAUFORT SC
yeah man I thought the dude was dead! he hit the floor so fast and blood went everywhere! it was bad! A piece of metal fell off of a shelf at work and smashed him in the head. It weighed about 6pounds and fell from about 4feet right into his head. Luckily we get free medical. that pic is of the 6 staples they put in his head!
Waternut
Customizing addict
Macon, GA
It's been a bad week for working on ski's I guess. I wear safety glasses when I use sanders, grinders, etc. but last Saturday I was using a razor blade to shave some excess foam that expanded over. The razor blade snapped and hit me in the eye... Luckily it only hit me in the white and there aren't any problems (that I know of) so I'll count my blessings on that one. I learned a new lesson though...
I think yours was worse by far.
N3vrSat1sfied
Military Member
Fort Worth, TX
well what can you do, sometimes stuff just happens.
So the MSD enhancer instructions say DO NOT use with timing advance. I know Ski4ever took his out and sold it to me so i have two plates now. But the questions is I need to pull mine out right? or can i run it with both?
N3vrSat1sfied
Military Member
Fort Worth, TX
I called MSD they said the plate advances it 7 degrees and in order to run the plate i need the retard kit which backs it 5 degrees. The retard is $54, so is it worth that to advance the timing two degrees or should i just pull the plate out?
Waternut
Customizing addict
Macon, GA
Wait I thought the whole point of having the MSD enchancer was to custom program your ignition... If that's not the case, what makes those things a) so expensive b) something so many people want?
you can just run the flywheel without the keyway and move it counter clockwise 1 tooth or so... i did that all last summer and it didnt retard once, the key way is only there for lining it up.
