This years set-up will be
X-Scream 771
X-Scream Mod Dual 46
X-Scream Boysen Intake with Rad valves
X-Scream Trim
Jettinetics Flywheel
Epic Ecu
Im going to also shorten my hull 2"
Turf the rails, and also thinking about modifying the rear rails like to ricter
As far as the the pump set-up Im rocking the Hooker 11/17 Nozzle bored to 85mm
I would be open to opinions and ideas
Is everything assembled and tuned to spec?
Is the throttle response crisp?
What are you comparing it to?
13/18 solas concord, I'm horrible with pitch numbers is that more aggressive or less the my 11-17 hooker?
I'm no expert, but I think a 13/18 concord is quite a bit less aggressive than an 11/17 hooker.
You can't compare the Hooker pitches with concord pitches. Given that we use 11/17 hookers with 8mm strokers and they work really well I would say thats too much prop for your engine, I think a 10/16 would be better suited.
Chris.
One guy has a stock impeller and the other guy is waiting for art to send him one lolSee about borrowing another impeller from one of your riding buddies.
your suggestion?12/17 skat c-75 swirl with TBM supercone. 85mm reduction nozzle. 701-828cc
your suggestion?
