i dont think this is much of a high force application.
how does hydraulics complicate things?
wouldn't it give you MUCH more leverage if it were a dual piston system?
other than rebuilding the pistons at given intervals, what problems are you referring to? hydraulic systems are watertight by their nature. otherwise theyd be leaking fluid all over the place, wouldnt they?
Dual pistons doesn't reduce the force you have to apply.
Here ya go.
Let's say it takes 100 lbs of force to pull the nozzle up. Somehow, someway, you have to apply 100 lbs of force up at the lever.
Say you have a 1" diameter cylinder down there, that's 0.785398175 square inches (less if you're on the shaft side) so you'll have to generate 127.3239 psi to move it.
Ok, up at the lever end you have to make that pressure.
If you have a 1" diameter cylinder, you'll have to apply 100 lbs of force.
If you change that to two .75" diameter cylinders, that is 0.8835729 square inches of piston surface, so you'll have to apply 112.5 lbs of force to the lever to move the cylinder. That is a harder lever pull.
However, change those cylinders to .5" and your force drops to 50 lbs. The problem with that is, you're displacing less fluid as you move it, so you you'll have to have a longer lever throw to get the same throw at the nozzle end.
