- So. IL
can you show a pix on how and what you used to support the end of the cable housing.. THANKS
While looking at the pump from the rear I drilled the top left hole so that the cable fits through the pump. The cable end holds the pump together at the reduction nozzle and the wear ring side gets a nut and bolt on that side. Then the other three 10 inch bolts hold the pump assembly together.
About the steering with the protec setup you need have the ends of the thingys (insert proper name here) only screwed on the cable about 4 or 5 threads because of the length of the nozzle anyhow. But I am going to get a threaded furrel and cut it at 45 degrees and then reweld it so that the steering cable has a 45 degree bend on the last 2 inches so that when the nozzle is turned all the way it will keep the cable off of the pump. This is how I broke my last steeering cable with it trimmed all the way up and turned to the right the cable attachment point is kinda tucked behind the nipple that your water line hooks to so it bends the steering cable. You can move the ball for the cable to under the nozzle so that there is more clearance but with that much throw the cable needs to be attached in the center. If not when you trim the nozzle up the steering is turned about 10 degrees to the right.
Wow pictures are worth 1000 words. I will try to get some better pictures this weekend and post them. I will have the steering cable ran and installed by next week. I will get some new pictures then also.
