SXR-FOREVER
Finally Flippin
- Lake Minnetonka, MN
What skat trak cable did you use? Also, did you use the x2 nozzle or modify your sxr one? If you used the x2 one, did you bore it or just bolt it on? Thanks
Used the SkatTrak that Blowsion sells and used a full X2 reduction/trim/steering set up. Only problem was that I kept breaking trim cables (3) so I'll have to try a different wayof going about it.
