blaster4life
couchez r 4 living rooms
- illoinis
tough crowd
ill the terry cable work with the complete Protec setup? the guy that sold me a "new" Protec system sent me a bunk a$$ cable with a 2" threaded shaft on one end...
WaverRaider parts.
Reduction nozzle - $100
Trim Ring - $35
Turn nozzle - $25
Pivot bolts and bushings - $14
Trim lever from a bike shop - $10
12 foot long trim cable from Terrycable - $30
There are cheaper ways to do it as well, but these are all the approximate new prices.
I use a SuperJet reduction nozzle with boss' welded to it so that I could drill and tap the holes for the trim ring. Doing it this way gives me 25 degrees of throw.
I also bored out the pump bolt hole on the upper left side of my pump in order to run the cable straight through.
The Terry cable only has a barell on one end???? WTF
i have a spring and it still doesnt go back as fast as my throttle.:stups:Are the lever's on your trim set-ups snapping back as quickly as you throttles?
Mines goes back into place easily but not nearly as fast as my throttle snaps back?
Any way to rig up a spring or something?
Thanks
I don't understand springs on trim nozzles. your jet thrust will straighten out the turn nozzle just fine.
Springs are for trailer riding.
can anyone answer about why i have so much slack? I cant adjust my cable anymore, and when i pull it in i can push the nozzle about 1 inch more up.
