OCD Solutions
- Rentz, GA
Coming along quite nicely. Wait for the sticker shock on the insulated doors.
Already quoted, on the high end of $9000, low bid of $4400, and am at $7000 which l will probably use, He did a couple doors for a friend and did great. More than likely the low bid had more vinyl in it than the others! These doors that are being quoted were metal on inside and outside with insulation, commercial grade garage door openers and installed. Most of the cost is on the materials. Installation was around $1100 for both doors. Honestly, for me to install isn’t worth it. You cannot beat a man at his craft.Coming along quite nicely. Wait for the sticker shock on the insulated doors.![]()
Those liftmaster 8500s are what I installed. Bought them in a 2 pack from Amazon for the cost of a single one from my local garage door company. I paid 4500 for 2 12w x 10h doors and installed them myself. I got quoted about 10k for doors and install so I had to do it myself to stay on budget. Luckily I worked across the street from the door supplier for 15 years so they cut me some slack when it came to pricing too!That sounds about right. I was shocked by the cost of the door for my shop but it ended up being a much better quality door than I had ever owned before so I feel it was worth it.
If you go with a Liftmaster Jackshaft type opener, they now come with a locking feature that drives a deadbolt into the track to prevent the door from being manually released and opened. I really like this feature!
l will have to ask my guy about the dead bolts. Thanks for the heads up!That sounds about right. I was shocked by the cost of the door for my shop but it ended up being a much better quality door than I had ever owned before so I feel it was worth it.
I spent $59.99 on a single door insulation kit today. Installed it in about 30 minutes. My garage temp just went up a few degrees.Coming along quite nicely. Wait for the sticker shock on the insulated doors.![]()
For right now, not much. Electrical and plumbing, then insulation. Most importantly, l need to get the garage up and running. l use it a lot for work.They should be able to knock that exterior out in a few hours, it is looking really good, I am so jealous.
How are you finishing the inside out ?
Snow wasn’t much but the damn temps were awful. Like east tn, looks great for a few days and goneYour exterior colors are nice Don I like it a lot! Wife made me go gray for ours to match the house. Hope the snow wasnt too bad up your way. Most we have had since the 90s down here.
The whole thing looks really good so far , what are you using for insulation , I am insulating an 100 year old home I am about to restore , it had no insulation except the fiberglass I put in the attic so all the exterior walls are coming off and being reinstalled , luckily it's painted Western cedar under the nasty aluminum siding , I am flipping it over running the edges through a joiner and reinstalling it.For right now, not much. Electrical and plumbing, then insulation. Most importantly, l need to get the garage up and running. l use it a lot for work.
The back side (man cave part) will get drywall and some sub walls. Will finish out the bathroom probably as the next step.
Going with wood grain garage doors. Didn’t intend on the color, but the owner of the business came out yesterday to do the final measurements and had one door that was ordered wrong from another job and gave me a discount on it and another. Looks good with the blue.
Decided against closed cell foam. Moisture is my issue with spray foam. We have cold or cool mornings, then warm/hot days here in NE Tn. So the plan is to blow insulation in the attic, then for the walls, 3” Rockwool with bats of fiberglass over it. From research that seems to be the best combo. Rockwool only does so much, but it is a good sound barrier and then the added glass to finish it all off. Shop gets osb and man cave gets drywall.The whole thing looks really good so far , what are you using for insulation , I am insulating an 100 year old home I am about to restore , it had no insulation except the fiberglass I put in the attic so all the exterior walls are coming off and being reinstalled , luckily it's painted Western cedar under the nasty aluminum siding , I am flipping it over running the edges through a joiner and reinstalling it.
I got a smoking deal on a truckload of Blue Dow foam from a chicken house teardown delivered dirt cheap, the panels were 1 1/2 thick 4 FT wide X 20FT long, I cut them down on the table saw to fit between the studs and I am using right stuff to seal up the gaps. I am doubling it up for 3 inches of solid foam insulation.
If you can swing the cost spray in is an excellent product , well worth the money in the long run, plus they do all the messy part lol.
