- Winter Park
Looks like I've got one on the way!
Now to decide whether or not to knock the magnets out...
Do it- takes 2 mins with a hammer and big flathead- mine came out in 2 big chunks
I'm not a distributor but usually order a couple at a time to save on shipping and have one or two extra on hand.Or you could start with magnets then knock them out if you want more response. It would be interesting to get the A-B comparison while using the same ignition curve.
Do we know if any US distributors will be getting there hands on the PCI-2? I plan on picking one up this winter and would rather buy from someone in the states.
yes just leave it the way it is. The timing is done off cranks shaft degrees of rotation not of the stroke.@waxhead is there anything different I need to do with your curve since I have a +5mm stroker?
I was just curious more than anything.. I like "simple and works" and easy to change parts lol..An msd flywheel is still a fair bit lighter then a lightened stocker with no magnets. You could always use a lightweight charging flywheel or the jstl system was a zeeltronic brain setup with its own trigger system and used flywheels already on the market
what's the weight comparison to an MSD TL flywheel and a lightened stocker with magnets knocked out? also do you have a chart of what the "wax"curve is? Im considering trying this on my 1105 on pump gas.. and a few other small motor flat water skis im building. unless there's a plan for a direct replacement 62t cdi..
Have you measured it, I didn't think it was that much different by the time you had machined all the steel down as well.An msd flywheel is still a fair bit lighter then a lightened stocker with no magnets. You could always use a lightweight charging flywheel or the jstl system was a zeeltronic brain setup with its own trigger system and used flywheels already on the market
When I designed the curve i kept it quite mild so i didn't/ couldn't do any damage there is more to be gained for sure. Thats the awesome thing about the zeeltronic![]()
The red curve- it’s a safe and effective curve that is still more aggressive than an msd enhancer
I started with that curve and then switched to a more aggressive curve myself.
No. I don’t have a copy of the msd enhancer here with meDo you have your curve compared to the enhancer?
