jdsfel
- LaPorte, IN
You've got it.
Got it. Thanks
You've got it.
Thats me doing it. i am in the middle of a house move and also getting a ski ready for the world finials. Its killing me, my workshop is in more of a mess then normal as well due to the move. I am getting there and I will have it wired up soon. I know every one is waitingI see talk of testing for kawi 1100. Is there a zeeltronic I can order currently available for an 1100? With or without a curve.
Can I run a 701 coil in place of the 760 coil? Electrically speaking, is there a difference between the two?The are the same when it comes to the zeeltronic. You cant run a std 760 cdi of an 800 flywheel or vice versa but the zeeltronic is a dc/cdi so it does'nt care
I don't think it matters. I run a stock 701 coil.Can I run a 701 coil in place of the 760 coil? Electrically speaking, is there a difference between the two?
I put a 701 coil in mine when I was trouble shooting my ski. I was able to use one of the extra ground connectors left over from removing extra wiring to ground my coil.You can if you attach a ring terminal to the bullet connector/or cut it off and add a ring terminal. Then attach it to an isolated ground such as one of the coil mounting bolts. If you go back a few pages I have pictures of it.
I'm having great luck with my Zeeltronic setup. It hits and revs to the moon. I'm wondering how long my total loss system battery will last. I've gone three tanks without recharging. How many tanks can I go? Wondering because I'm going to the mountains where I might not be able to recharge for a bit.
Ok silly question.... if you remove the magnets from a stock flywheel and stock ignition setup will the ski still run?
Lol, awesome. Ok so I'll swap my stock gp800 flywheel back on until I pull the trigger on the zeeltronic setup....
Who sells here in the states and how much???
so the 64x triggers off the lumps and the others are triggered by the magnets and their position in relation to tdc?
