- Glenmoore pa
Disregard ^^ the start stop white wire was crushed in the box and grounding out. That’s what I get for rushing (kinda have to when your MSD system takes a dump and weather is nice)
Did you check base timing at all?
I’d be curious if the static angle is different and therefore the entire curve is offset by a few degrees.
Were you running a lightened TL flywheel?
The fact that it went lean down low tells me that in fact you now have more advance then previously. What pop off were you running on your carbs ??.
Im not discounting your findings but it does different than I have experienced. Then again i dont flat water back-flip. I would think the light weight msd is the key here. A light weight alloy flywheel is still going to be lighter than the lightened stock 760. I am genuinely interested in your findings. we are working on an alloy total loss flywheel system in conjunction with zeeltronic that will go on place of the stock 62t gear. I am making the flywheel and stator and he is supplying the cdi and pickup. This may make the difference.
00:
01: PDCIS-02T <device ver>
02: 00 <boot ver>
03: 20.200409 <software ver>
04: 0000 <data ver>
05: 56 <static angle>
06: 8750 <rev limit>
07: 30 <delay comp>
08: 2 <pulse per rev>
09: 1 <ign setting nr>
0a: 18 18 33 33.0 33.0 11.0 9.0 9 9 9 15 15 <ign angle #1>
0b: 18.0 18.0 33.0 33.0 33.0 11 9.0 9 9 9 15 15 <ign angle #2>
0c: 1000 1500 3000 4500 6000 7000 8750 10500 11000 11500 12000 13000 <ign rev #1>
0d: 1000 1500 3000 4500 6000 7000 8750 10500 11000 11500 12000 13000 <ign rev #2>
0e: 10 10 <nr ign points>
0f: 0 <advance>
10: 0 <ign sw>
11: 2 <trigger mode>
12: 0 <stop sw mode>
13: 1 <latching stop>
And your pulling it out a lot harder up top as well.well i'll be dam$ed.- I bet the ramp up had an impact! MSD gets all the timing in by 1500rpm.... my zeel curve has it come in at 3k.
